Please tell me the difference from UTM
craft
Just browsing
I would like to ask you about the GX20.
Although it is introduced as a security gateway that has both a router function and a firewall function,
What is the difference from UTM such as FortiGate?
2 Replies 2
Soichiro-Ono
For reference
UTMとの違いを教えてください - The Meraki Community
有用な回答だと思われる際にはkudoをクリックして頂けると幸いです。
回答があなたの問題を解決した場合、accept as solutionをクリックしてください。
LuckyLionTamer
Meraki calling the routers "Security Routers" is a bit misleading as they only work as a basic NAT/stateful firewall.   They don't appear to do any actual traffic inspection or IDS/IPS or anything along those lines.    They don't even block ALL incoming requests from the internet (you'll notice you can ping your public from literally anywhere), so it's happy to advertise its presence to the internet, something even your basic ISP's router will not do.
They do offer an outbound DNS based security solution, but that's something you could apply to any other router which allows you to set your external DNS.
If you look at the feature set of the Meraki Go routers vs something like Ubiquiti's USG series, there's a MASSIVE difference.
