Meraki web page does not automatically fit any size of screen
CarmenMarino
Hello all,
Does anyone know if Meraki will make the web interface to automatically fit any size of screen?
In the wireless access point list view, it is quite inconvenient when searching and navigating through all the columns you can add. Most of the screen is empty, and the table with the AP information only fills a predetermined size that cannot be adjusted.
Meraki portal Web InterfaceMeraki portal Web Interface
Thank you so much in advance!
1 Reply 1
ArtMarshall
Meraki Alumni (Retired)
Hi CarmenMarino,
This is a better question for the Meraki Dashboard community.
This forum is only for Meraki Go.
