Meraki Go App reporting hardware offline
Franco244
Swapped out a GX20 for a GX50, process took a bit longer than I had hoped. GX50 took approximately 10 minutes to come online, it needed to fetch it's config at least 4 times before being applied successfully. Once online, none of my other hardware were coming online. Rebooted stack twice, eventually everything was online. Nice!
Today I decide to check the app, and I see that under the health page, I have a device(s) reporting offline. Check Web App, same thing. Reinstalled Android app, no change.
All hardware reporting online on hardware page. Health page says differently.
Any thoughts as to why the reporting is incorrect on health page?
Franco244
This issue has resolved itself and likely just due to latency on the health page if the app.
2 Replies 2
speakerfritz
had the exact problem last week
bought gx50
replaced my gx20 with the gx50
i properly removed the gx20 in the app .
added the gx50
in the cloud app everything was fine
on the iPhone app it showed the new gx50!was alerting.
let it run overnight to see if it would sync up
next day, same thing, cloud app was fine, iPhone app was alerting gx50
put in a ticket…no response
started a thread… no response
Just for the heck of it, I uninstalled the iPhone Meraki go app and reinstalled it.  Problem solved.
both cloud app and iPhone app show everything is fine.
btw, I posted my new internet speed if I use Ethernet which was almost 800mbps
but, via AP’s, even though my devices connect at 800 to the AP’s, I only get 375ish mbps internet speed.  I’m guessing is becuase I have a meshed wireless network.
gave not tried the con feature yet.
Franco244
