Meraki GX20 and ISP speed
GianniBorda
I currently have a 1GB download speed from my ISP.  Since the GX20 firewall throughput is 250MB should I lower my ISP speed (and save money)?
Thanks, John
1 Reply 1
Soichiro-Ono
Hello.
Unless you're a highway star, you might consider lowering your WAN line contract plan if sufficient effective speed is available.
Hope it helps,
有用な回答だと思われる際にはkudoをクリックして頂けると幸いです。
回答があなたの問題を解決した場合、accept as solutionをクリックしてください。
