Meraki GO - GR12 Wireless Access Point Reset Button Location
WebNL
For the Meraki GO GR12 Wireless Access Point…
  • The RESET BUTTON is located at the back of the device, near the Ethernet port.
  • Keep the ethernet cord plugged in, while using a thumb tack, push pin, paper clip, or straight pin to press the reset button for 5 seconds.
  • The GR12 documentation does NOT indicate the location of the reset button as of Nov-10-2022. Cisco should consider adding this info.
1 Reply 1
Soichiro-Ono
Hello.
Constructive reductions should be submitted to MaW.
Make-a-Wish (Feature Requests) - The Meraki Community
有用な回答だと思われる際にはkudoをクリックして頂けると幸いです。
回答があなたの問題を解決した場合、accept as solutionをクリックしてください。
