We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Quick questions:
How many SSIDs I can create per WLAN network? and what's max number of APs per network. Can I mix and match GR10 and GR60 on the same network?
Solved! Go to solution.
Hey @TongtongX,
Thanks @VincentPanico!
One minor correction - the maximum number of APs is 20.
If you have any additional questions, feel free to ask them here on the Community! 🙂
Hi TongTongX -
You can create up to 4 SSIDs. You can have a maximum of 15 20 APs. And yes, you can mix and match the GR10 and the GR60 APs.
Vincent
Thanks, @KatD! I corrected my post.
Is the AP limit per account actually 20 still?
This doc on Meraki's site says 50. https://documentation.meraki.com/Go/Meraki_Go_-_Support/Meraki_Go_-_FAQ
Can confirm, the limit is now 50
