GX50 site to site VPN. choosing a WAN exit for tunnel traffic.
Trunolimit1
I have a gx50 at two sites (site A and site B).
So I would like clients on site B to have the public IP address of site A.
is this NOT possible with the GX50?
In short I want the WAN exit node to be site A for a VLAN on Site B.
2 Replies 2
delfuego
Haven't played with this on the Meraki Go hardware, so I may be way off-base. They may have similar terminology and setup for Meraki Go. Hope this helps.
However on Meraki enterprise you have the option of Hub / Spoke VPN. 1 site is the hub, the other are spokes and send the data to the hub. Within this the is a setting for "default route". This would funnel all traffic from the "spoke" to the "hub" then out. This sounds like what you are asking for. The other option within this is a "split tunnel" (unchecking default route). This would only send data destined for the hub down the VPN tunnel, all other traffic is sent out the wan interface (not down the tunnel)
Trunolimit1
Thanks for the reply. Unfortunately the GX line has been neutered from the MX. None of that functionality exists. The only thing it can do is a split tunnel VPN and you can’t do policy based routing to send certain traffic over the VPN.
I am currently looking for another solution.
Go News & Announcements
