GX50 / S2S Error
jonathanbrct
GX50 / S2S Error
Hello Team,
I currently have 2x GX50 located on two different sites to make a S2S link to access specific resources.
However, despite configuring the local networks and setting up the S2S configuration, the link does not go up.
Do you have any idea why? Is there a "hidden" option available to get detailed logs?
Would someone who has already succeeded in setting up a S2S with 2x GX50 please come forward?
Is it mandatory to buy a license for this one?
Thanks in advance,
Regards,
7 Replies 7
jonathanbrct
Update, nobody have alreday setup an S2S VPN with 2x GX50 ?
Regards,
speakerfritz
I was going to google what s2s means…but then it hit me…site to site.
no…haven’t set one up yet.
jonathanbrct
Hi speakerfritz,
Yes, that's right S2S stands for Site To Site! Currently available between GX50!
Regards,
speakerfritz
Is there any chance your ISP is blocking needed ports.
I have 2 ISP’s.  One blocks everything
jonathanbrct
Knowing that one is behind a firewall, the problem is that I don't see any incoming traffic, and I can't find any specific documentation indicating the ports used by Meraki Go to establish the S2S.
speakerfritz
Most common site to site vpn ports are 500 and 4500, which is the same for enterprise Meraki ….I can’t imagine why Meraki go would not use the same.
me would use a port checker and test for 500 and 4500.
jonathanbrct
Hi Speakerfritz,
I found some information about setting up the Auto-VPN proposed by Meraki with additional ports, I will do various tests (https://documentation.meraki.com/MX/Site-to-site_VPN/Meraki_Auto_VPN_-_Configuration_and_Troubleshoo....)
Ports used to contact the VPN registry:
  • Source UDP port range 32768-61000
  • Destination UDP port 9350 or UDP port 9351
Ports used for IPsec tunneling:
  • Destination UDP port range 32768-61000
Or (https://documentation.meraki.com/MX/Other_Topics/Using_VPN_through_an_MX_Security_Appliance)
Regards,
