GX50 Port Forwarding
M-W-Computer
I'm trying to add a port forwarding rule. When I enter the local IP, there is no option to save and return to complete the forwarding rule. Not sure if there is a glitch in the meraki-go cloud.
2 Replies 2
Xydocq
hello @M-W-Computer
I assume you did try to add the portforwarding rule on web.meraki-go.com with a webbrowser. When I did try, I selected a device from list and the screen went all green.
Then I tried this:
1. Select the VLAN the device is on and go back
2. Go to Settings - Advanced Settings - Port forwarding
3. Entering the IP manualy, first thing to do and ADD should turn to ADD
4. Enter Name, Protocol, Local and Public Port and then SAVE it
It seems web.meraki-go.com is a bit buggy lately. The android app was working fine, without any problems. You might want to use your phone to set the rules you want to apply.
Cheers
M-W-Computer
Thanks for the info! I've knocked my head several times with this and didn't think to use my smartphone. Obviously, that's not my first choice for programming a router! Thanks again.
Gary
