Default Username and Password on Meraki Go GX20 and GR10
Bloom
I can't seem to locate what the default username and password is for the Meraki Go GX20 Security Device and the GX10 Access Point. This is for when I'm connecting directly to the devices and bypassing the app.
Appreciate any help.
Xydocq
Hello @Bloom
The default login on the Local Status Page is: username = serial number of the device, password has to be left empty
Meraki Go Local Status Page - Cisco Meraki
The GR10 Status Page might only be available if you connect over wifi.
Cheers
1 Reply 1
Xydocq
Hello @Bloom
Cheers
