GX20 reboots every morning.
awawa
There's no particular update announcement, but is everyone's GX20 OK?
I've been restarting it every morning since Sunday. Is it broken?
29 Replies 29
ConnorL
Meraki Employee All-Star
Drop me a DM with a link to the GX, or the serial number and I can take a look.
awawa
A lot of people seem to be having issues with their GX20. Any solutions?
ConnorL
As mentioned, drop me a message and I can take a look. Reboots can occur for a number of different reasons.
SMAT_jp
I'm having the same problem. I sent you a DM. Thanks in advance.
scottysmoov
Mine is doing the same thing. About 6:15am GX20 going offline.
Any news on what the problem is?
hmja
Since November 16th, I have been receiving an email alert every morning with the subject "Hardware offline alert (site name: ****)" for my GX20.
Then, about 30 minutes later, I receive an email alert with the subject "Hardware online alert."
It's inconvenient when the hardware is offline for those 30 minutes, so I'd like to know what to do.
trgeuy
I have been seeing the same issue. The uptime between outages appears to be 24 hours with a ~40 minute outage each time. Just opened a ticket with my ISP right before I found this.
scottysmoov
Make sure you've all raised a support case through the Meraki Go app. That why their service centre can see the extent of the problem and will up it's priority accordingly.
I have also reached out to my Contacts in Cisco. When I get an update I'll post it here.
1R191
Glad to see im not the only with this issue.  I raised a ticket and will be monitoring this thread.  Hopefully there is an update on this soon.
SMAT_jp
Since November 18th (Japan time), my Meraki Go GX20 has been repeatedly going offline,
coming back online after 40 minutes,
and then going offline again after 24 hours. Even after rebooting,
it goes offline again after 24 hours and comes back online after 40 minutes.
scottysmoov
Seems this problem is on going. My GX20 was down again this morning, it actually seems to happen every 25 hours, my outage is happening later each day.
I also checked the hardware info for my GX20. In the product information settings, next to Firmware it says 'Not Running Configured Version'. This suggests to me that maybe a faulty update has gone out.
Does anyone else have this?
1R191
I have the exact same issue.
kozu_hiro
私も同じ現象が続いています。
世界全体で起きている事象でしょうか。
SMAT_jp
私も同じ現象が11/18(日本時間)から毎日発生しています。どうもアップデートにバグがあったような話もありますがCISCOからはサポートには連絡しているものの音沙汰なしです。
kozu_hiro
ハード故障だと思い、GX20をAmazonで購入してしまいました。。。そのあとに、このサイトで同現象を発見しました。
toru
私のGX20でも同様の事象が発生しています。
丁度24時間なら時間がずれないのでいいのですが、オンライン(30~40分)から24時間後なので、もうそろそろ業務時間中にさしかかるため、シャレにならない。
kozu_hiro
SMAT_jp
私もカートにまでは入れてしまいました。買わなかったけど
kozu_hiro
新古品ですがAmazonで残り1個だったので、他に買われるとまずいと思い、私の方が先に買ってしまったかもしれませんね。会社で使っているものだから、毎日、オフラインになると仕事になりません。。。
SMAT_jp
私もテレワークで使っているのでGX20壊れたか?と思い再購入をまずは考えてしまいました。
ひとまず手動で再起動したら(まあ、家のネットワークをすべて再起動しましたけど)繋がったので様子をみていて『一応コミュニティ見てみるか?』でここにたどり着きました。
今のところ寝る前にGX20を手動で再起動することにしています。そうすれば24時間は使えるので....(笑)
AmandaRD
Same issue. Filed a ticket. Does anyone know if we can avoid this by doing manual restarts at a more convenient time? It’s happening during our morning coffee shop rush now and is really affecting business.
Wisekrak
This began for me about a week ago. My theory is that a firmware update is trying to get pushed to our gx20’s and it is locking them up. Mine first locked up a week ago a little after 4:00AM. This is the time that I had set in the app to perform updates as to avoid interruptions. After power cycling everything is back up but under the GX20 details it states under firmware”Not running configured version”. That tells me that the upgrade failed and the device is running on the previous firmware.
then the next day it locks up nearly 24 hours after I power cycled the device. My theory here is that the cloud management realizes the firmware upgrade has failed and waits 24 hours to attempt again, resulting in a locked up router. The time the lockup occurs has been shifting forward each day as I have been getting the device back online sometimes 30 minutes after the lockup. Then another 24 hours passes, and it locks up again. Thiis morning after nearly a week if this issue the lockup occurred about 8:15 AM as I expected because that was about the time I got my device back online yesterday.
I have a lot of experience with Meraki’s enterprise product line and with those’d devices like the MX64 or MX67, you have a lot more control over the firmware updates. You can select beta versions vs stable, and you can schedule firmware updates with very granular control. You can even force the update immediately in order to get it to complete successfully while everything is already offline and I really wish I had that control on this product line.
i have been hesitant to perform a factory hardware reset if the device because of scars I have had in the past with enterprise MX64’s refusing to connect to the Meraki cloud and pull the config or firmware after doing so. I may just have to gamble on that soon because since I cannot control the deployment of firmware, the only other setting I have not the time to perform the upgrade. And I think the 24 hour retries are now in effect and changing the update time would have no effect.
SMAT_jp
For the time being, I don't use the network much late at night, so I manually restart it before going to bed. That way I can use it 24 hours a day.
SMAT_jp
手動でrebootのテストをしたところ タイミングによってはLEDがレインボーと赤を定期的に繰り返して立ち上がらなくなりました。(10分以上放置) ご注意ください。電源ケーブルの抜き差し(10秒以上放置)で復旧しました。
When I manually tested the reboot, depending on the timing, the LED repeated the rainbow and red regularly and stopped standing up. ( Leave it for more than 10 minutes) Please be careful. It was restored by unplugging and inserting the power cable (left for more than 10 seconds).
kozu_hiro
私もその経験があります。再起動しても立ち上がらないことがあり、ハード的に故障したのかなと思ってしまいました。
kozu_hiro
ルータを別の製品(他社製品)に変えて解決しました。
ConnorL
Hi folks,
Thank you for sending over some example units, spot checking these I can see they're failing to upgrade to MX 19.2.4 and therefore rebooting every 24hrs. We've got a bug pending review whilst we gather some additional data points before sending this over to Engineering. Thank you for flagging these here, no need to send me any additional units.
If you haven't already, please ensure you raise a case so this can be properly tracked.
Ben-Wilson
Just browsing
Thanks for this thread as I was going crazy trying to fix this issue and was pointing the finger at my ISP.
Do we have a time frame for when this will be resolved just so I can manage client expectations?
Thanks.
scottysmoov
At the moment we have just been informed that Engineering are working on a fix, but there is no timescale. Updates will be sent when they have them.
The only work around seems to be to reboot your router at a convenient time, you then get 24 hours before it'll reboot itself again.
