Disable ping on WAN interface?
LuckyLionTamer
How do I disable a GX20 router replying to pings from the internet?  It's a bit odd that the default is to have this enabled, but I don't see an option to disable it in the app.
Thanks!
1 Reply 1
Soichiro-Ono
Hello.
Since there is no setting item, I think that the desired function is not implemented.
Regard,
有用な回答だと思われる際にはkudoをクリックして頂けると幸いです。
回答があなたの問題を解決した場合、accept as solutionをクリックしてください。
