Device usage limit not saving
Mendo54
Just like the title says, when trying to set a device usage limit, I hit the save button but my setting does not save. When I go back into the setting, it’s off and if I test, that device is still able to consume full bandwidth. I’ve tried setting this on the mobile app as well as the website dashboard. This happens for any device.
1 Reply 1
Soichiro-Ono
Hello.
Sorry to trouble you, but please reset to the initial state and try again.
Regard,
有用な回答だと思われる際にはkudoをクリックして頂けると幸いです。
回答があなたの問題を解決した場合、accept as solutionをクリックしてください。
Go News & Announcements
