Can you configure a GS switch with a static Management IP and gateway - if so how?
RichardTyrrell
I can find documentation regarding configuration once the device is working but if you needed to place a switch on a network without DHCP and configure it with a static IP/Gateway so it can reach the internet in the first place? The static would have a path to the internet.
If not can you place it on a network where it picks up DHCP then change the management IP /Gateway to a static through the GUI?
2 Replies 2
Xydocq
Since I don't own a GS-device, I'm not sure if you can do that.
The GX20 can be accessed thru a LAN connection directly (prior or after initial setup), by entering the local IP in a browser. Username would be the Serial-Number of the device, password isn't required. This leads to a basic setup-page where you can set Internet-Connection-type and port-management (disable/enable).
Maybe the GS offers something similar?
Soichiro-Ono
Hello.
Please refer this section.
Meraki Go - Local Status Page - Cisco Meraki
>Configure: This tab allows editing the uplink IP address settings.
Regard,
有用な回答だと思われる際にはkudoをクリックして頂けると幸いです。
回答があなたの問題を解決した場合、accept as solutionをクリックしてください。
