Application rules / limit
MoRo
Currently I can't set more than one application rule / limit on one SSID. Only with global settings I can set more than one specific limit. Is there a reason why I can't set more than one limit on a specific SSID? Or is it a bug?
1 Reply 1
hidden0
Meraki Alumni (Retired)
Hello @MoRo
My apologies for the delayed reply.
You can set multiple usage limits per network. When on the Usage Limits screen, where should see your current application rule, press the button to add a new rule specifically to that network.
