Known Issues
AlexanderN
Meraki Employee All-Star
These are the broken things we are aware of.
Issue:  APs respond to active probe requests with hidden SSID values
Explanation: Basically, clients that do active probing can "see" hidden SSIDs.
Issue: APs report multiple SSIDs under Interfering APs (Wireless > RF Spectrum) at -40 dBm that are not seen by clients or non-beta APs
Issue: Local status page not loading on mesh repeaters
Description: A local status page is not there
Issue: APs are not sending LLDP packets to the upstream devices.
Description: APs only send CDP packets. Older APs send both LLDP and CDP.
Issue: APs report PoE warning
Explanation: Beta APs only need 802.3af (PoE) power. They do not require PoE+ (802.3at). However, MR45 APs do require PoE+. Since the model number for these units is not yet finalized and the Dashboard sees them as MR45 this is a false positive.
