hi!
Amber1
hi!
Hi all!
I'm Amber and I work for Verizon currently as a Solutions Architect in the software space. I've not worked much with hardware directly but used to support IoT projects so I had limited interaction with Meraki.  I am excited to be part of this community as I believe it will be beneficial to understand more about the infrastructure of the solution and how I can help support my customers.  Not sure if this is fun, but... amid this pandemic and homeschooling I can confirm I was not meant to be an elementary teacher.
5 REPLIES 5
DJDonovan
Meraki Alumni (Retired)
Welcome to the community! We're glad to have you!
MeredithW
Community Manager
@Amber1 wrote:
Hi all!
haha, well now you know! Welcome 🙂
Meredith W | Community Manager, Cisco Meraki
Found this helpful? Give me some Kudos! (click on the little up-arrow below) New to the community? Get started here
I think that's funny!
Welcome to the community.
KRobert
Welcome to the Community!
CMNO, CCNA R+S
QLSteve
Its how you learn!  Definitely don't have what it takes to be a teacher either!
