Meraki Insight
Meraki Insight
When is Meraki Insight being released, and when can get get access to the pricing?
6 Replies 6
Adam
Looks interesting, I hadn't even heard of it yet.  So seems to say "new Meraki Insight license".  So I guess they are adding another add-on or option to these? https://documentation.meraki.com/zGeneral_Administration/Licensing/Cisco_Meraki_Licensing_Guidelines...
Adam
Reply I got from our rep "Meraki will have a launch in Mid March for Insight."
MRCUR
I don't believe the license will be tied to the MX but will be separate as this is a separate product that uses MXen for gathering data (at least in the initial version).
MRCUR | CMNO #12
Adam
Correct, the product is being marketed as something that can be used with non MXs as well.  Sounds like they are going to sell it based on bandwidth.  So, for example, a 250M license which would be the equivalent of a MX64 will likely retail at around like $400/yr.  I'm sure none of the info above is solid yet though until we get it in full release.  At those estimated price points I look forward to doing a demo of it and possibly purchasing.
MRCUR
The first piece of documentation has been published: https://documentation.meraki.com/Meraki_Insight/Application_Analytics
Note that MX 14.20 is required (I assume this is a requirement for the GA version and not beta...).
MRCUR | CMNO #12
MRCUR
Followup to the firmware requirement: The MX250/450 platform needs to be on MX 14.24 at a minimum for Insight to function properly. Earlier versions on the 250/450 platform while using Insight might result in unexpected reboots.
MRCUR | CMNO #12
Meraki Insight forum closed
This forum is now closed. As of July 26, 2024, Meraki Insight licenses are no longer available to purchase. MI functionality is now included in the SD-WAN Plus or Per-device SD-WAN Plus licenses. You can view more information about this on our End-of-Life Products and Dates page, Product “LIC-MI”.
Please ask any questions about MI-related functionality in the Security & SD-WAN board.
