More a question of what others are doing rather than an issue. I'm looking at log management software and I wondered what others are doing when it comes to Meraki, are you simply sending Syslog to a on premise server or are you using the API to pull logs?
Syslog options on Meraki are very limited so that won't work with all of the cloud based providers I've looked at as they all require a custom header or an agent installed.
