Printer connectes to which switch?
MSH
How can I determine which switch a printer is connected to; even if the switch is not in the dashboard (because he is older and has not yet been converted, but is actually a cisco switch)...
Kind regards, Volker Boeckl
DarrenOC
Look at the ARP table of the VLAN that the printers are in.  Trace through the network using the device MAC to see where the printers are connected
11 Replies 11
jedimaster
Have you tried running SHOW IP ARP from the switches?
MSH
No; but it wasn't the subject of my question...
Replace the old switch with a new Meraki switch.  Repeat.
MSH
Thank you, but your answer is useless. It wasn't the subject of my question...
The non-Meraki switces - what do they plug into?  An MX, an MS, or something else?
DarrenOC
Hi @MSH , I believe that was meant with a bit of tongue in cheek 😁
DarrenOC
MSH
Thank you very much! That was a very good hint!
DarrenOC
No problem. Works a charm every time you need to go device hunting
jedimaster
Glad I could help!
jedimaster
You could go old school and use a test/toner to trace the wiring if you are onsite.
