Meraki Access Manager and integration with Intune
samoyk
I have a customer who is using Intune as their MDM/posture enforcement. They are interested to enable and try the new Meraki access manager feature but it doesn't look like the early release of Access Manager supports any integration with other MDM solutions like Intune. Is this correct ? Any idea if it is in the roadmap?
8 Replies 8
Mloraditch
Roadmap is generally only shared under NDA. If this is important to you, your account manager may be able to let you know if this is officially on it and what the timeline is.
samoyk
Thanks but is it correct that the feature is not there yet ?
Ryan_Miles
Meraki Employee All-Star
Entra only today
The first caveat to know is that you can only do certificate-based authentication against Entra ID.  You can no longer do username/password authentication.
I currently have this setup and working:
  • All Intune-managed machines.
  • Using Intune CloudPKI to issue certificates to all devices (this is an additional Microsoft license).
  • Using Meraki Access Manager to authenticate users based on their certificates against Entra ID.
EdNunez
Did you have to disable MFA for the Access Manager Enterprise App in Entra?  I have it set up but when I try to connect to the SSID, I get the following message.
Failure/ Rejection info
Reason
MFA is required for authentication.
You can no longer disable MFA in Entra ID once your authentication policy has been migrated (which happens automatically by Microsoft if you do nothing).
The instructions for using Meraki Access Manager with WiFI for username/password authentication no longer work.  You can only use certificate-based authentication.
Jhippleheuser
Hey Philip,
Would you mind giving me some insight because I'm trying to achieve the same thing but I'm having a heck of a time getting everything to work together. So far I've been able to push down my trusted certificate profiles to a test computer but the SCEP is failing for some reason
These are the settings I am using for machine-based SCEP certificates.
I don't believe the SCEP certificate deploys till you use it in something, like the SSID config.
