Hello and thanks you. I'm now told that the SVI's will sit on an SD-WAN router above the MS425 Stack.
The MS425 will be for distribution only and the Lan switches (MS225s) will be below the distribution switch.
1. So, I run Layer two trunks between the lan and the MS425 through the port channels, yes?
2. How do i get from the distribution switch to the SDWAN, something has to point to the VRRP vip doesn't it?
3. Where should the Default gateway for my LAN switches point? To the VRRP address of the SD_WAN router, or the management address of the Distribtion switch?
4.Should the connection between the Distribtion switch and the SVI router be layer three or layer two trunk?
T
