MIB Changes - Luke Warm Spare Fail Over vs. vpnFailOverDetected
DonL
In the MIB I got from the console a * while* ago  7.6.23 was a fail over trap
# warmSpareFailoverDetected networkName
1.3.6.1.4.1.29671.1.1.7.6.23 0x06ba0016 1.3.6.1.4.1.29671.1.1.2.1.2(1,2)\
# organizationName
1.3.6.1.4.1.29671.1.1.1(3,0)\
# devMac
1.3.6.1.4.1.29671.1.1.4.1.1(4,0)\
# devStatus
1.3.6.1.4.1.29671.1.1.4.1.3(5,0)
Someone Compiles some Discount MIB while I'm *Away*
# vpnFailoverDetected networkName
# organizationName
And Warm Fail over is not vpn fail over ???
Did the that trap Change from one version to the *Next* "
True or False "
Thanks,
Don
2 Replies 2
Warm Spare refers to the redundancy of the MXs, VPN fail over refers to the VPN, they are different things.
If there have been any changes, only Meraki will be able to inform you, so I suggest you open a support case.
DonL
Indeed they do refer to differing conditions - which make it more concerning that they should somehow Both be tied to the same trap ?
Thanks,
