MERAKI BACKUP AND RESTORE
Hi guys,
Good Morning.
Just want to hear your unique ways about how to backup your configuration in the dashboard to your local drive.
In my situation i had an MX65W with configurations already and then i will have a new MX65W coming to be use in another organization.
My question first is how can i backup my configuration from my existing MX65W so that i can use it to my new MX65W? (But this is answered already by meraki support so they provide me a link  : https://documentation.meraki.com/zGeneral_Administration/Templates_and_Config_Sync/Cloning_Network_S... ).
In this link i just saw how to clone from network to another network in one organization.
Now, i want to hear from you guys if you experience this already and how you tried to backup from one organization to another organization.
Thanks in advance.
40 REPLIES 40
Re: MERAKI BACKUP AND RESTORE
Thanks @PhilipDAth , i would try this now.
Config Sync and Templates is the native way of replicating configuration from networks which need to be re-used and re-purposed else where.
If you're wanting to back-up the configuration to a local file you can do this via scripting and the API. @PhilipDAth has created a script for this purpose. I've tested it and works fantastic!
Hey @WANKiller or @PhilipDAth  could you pleaes indicate me where is that script ? thanks in advance.
Check out the second post.
thanks Philip , good idea about that script btw . Regards
Just browsing
I am getting an error message that I haven't seen in any of the other replies. When I run the backup script I get:
Traceback (most recent call last):
File "C:\Users\bry\AppData\Local\Programs\Python\Python38-32\scripts\meraki-backup.py", line 200, in <module>
from dotenv import load_dotenv
ModuleNotFoundError: No module named 'dotenv'
I think I missed one step.  Try:
pip install -U python-dotenv
Let me know if that fixes it and I'll update the instructions.
Just browsing
That did get me past that error. Now I am getting this:
Processing network correct network name
warning: MX VLANs disabled - wont be able to restore IP addressing
File "C:\Users\bry\AppData\Local\Programs\Python\Python38-32\scripts\meraki-backup.py", line 251, in <module>
write_ssid_settings(file,meraki,row['id'])
File "C:\Users\bry\AppData\Local\Programs\Python\Python38-32\scripts\meraki-backup.py", line 180, in write_ssid_settings
mySSIDs=meraki.ssids.get_network_ssids(networkid)
File "C:\Users\bry\AppData\Local\Programs\Python\Python38-32\lib\site-packages\meraki_sdk\controllers\ssids_controller.py", line 117, in get_network_ssids
self.validate_response(_context)
File "C:\Users\bry\AppData\Local\Programs\Python\Python38-32\lib\site-packages\meraki_sdk\controllers\base_controller.py", line 94, in validate_response
raise APIException('HTTP response not OK.', context)
meraki_sdk.exceptions.api_exception.APIException: HTTP response not OK.
That means it is failing to get a list of SSIDs in your network.
What kind of WiFi device do you have in your network, and are you an Organisation admin so you have rights to read the properties?
Just browsing
I just have one Ubiquity Unify WAP. I am an organization admin.
@Cardinal ,
So you don't even see a "Wireless" section in the dashboard, correct?
Do you have an ordinary MX (like an MX64) or one with WiFi integrated (such as an MX64W)?
Just browsing
Right, there is no "wireless section". I see an option to set up a wireless concentrator, but I haven't done anything with that. It is an MX 64.
I found this erro when executing. I am not really familiar with python.
Try changing these three lines from:
del mySNMP['v2CommunityString']
del mySNMP['hostname']
del mySNMP['port']
to:
if 'v2CommunityString' in mySNMP:
<tab>del mySNMP['v2CommunityString']
if 'hostname' in mySNMP:
<tab>del mySNMP['hostname']
if 'port' in mySNMP:
<tab>del mySNMP['port']
Make sure you replace "tab" with the tab key.  Formatting is very important in Python.  Let me know if it fixes it so I can update the main script.
Thanks @PhilipDAth I will update you once done executing.
C:\Users\Lenovo\Desktop>python meraki-backup.py [API-KEY] "Ardent Network Inc"
Processing network MY NETWORK
Processing network NGKHAI
HTTP Status Code: 404 - No returned data
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\urllib3\connectionpool.py", line 601, in urlopen
chunked=chunked)
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\urllib3\connectionpool.py", line 346, in _make_request
self._validate_conn(conn)
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\urllib3\connectionpool.py", line 850, in _validate_conn
conn.connect()
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\urllib3\connection.py", line 326, in connect
ssl_context=context)
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\urllib3\util\ssl_.py", line 329, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\ssl.py", line 407, in wrap_socket
_context=self, _session=session)
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\ssl.py", line 814, in __init__
self.do_handshake()
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\ssl.py", line 1068, in do_handshake
self._sslobj.do_handshake()
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\ssl.py", line 689, in do_handshake
ConnectionAbortedError: [WinError 10053] An established connection was aborted by the software in your host machine
During handling of the above exception, another exception occurred:
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\requests\adapters.py", line 440, in send
timeout=timeout
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\urllib3\connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\urllib3\util\retry.py", line 357, in increment
raise six.reraise(type(error), error, _stacktrace)
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\urllib3\packages\six.py", line 685, in reraise
raise value.with_traceback(tb)
chunked=chunked)
conn.connect()
self.do_handshake()
urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionAbortedError(10053, 'An established connection was aborted by the software in your host machine', None, 10053, None))
File "meraki-backup.py", line 184, in <module>
write_ssid_settings(file,apikey,row['id'],suppressprint)
File "meraki-backup.py", line 121, in write_ssid_settings
myRules=meraki.getssidl3fwrules(apikey, networkid, row['number'], suppressprint)[0:-2]
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\meraki\meraki.py", line 1703, in getssidl3fwrules
dashboard = requests.get(geturl, headers=headers)
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\requests\api.py", line 72, in get
return request('get', url, params=params, **kwargs)
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\requests\api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\requests\sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\requests\sessions.py", line 640, in send
history = [resp for resp in gen] if allow_redirects else []
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\requests\sessions.py", line 640, in <listcomp>
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\requests\sessions.py", line 218, in resolve_redirects
**adapter_kwargs
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\requests\sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "C:\Users\Lenovo\AppData\Local\Programs\Python\Python36-32\lib\site-packages\requests\adapters.py", line 490, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionAbortedError(10053, 'An established connection was aborted by the software in your host machine', None, 10053, None))
Hi @Ritchie.  Just edit that last post and remove the API key from from the command line.  I'll have a look at the rest.
I see it got upset when retrieving the SSID Firewall rules. I haven't tested against a M65W before, so I'll go try that.
So the prior change I gave got you past the SNMP issue?
I have a couple of thoughts.
Are you perhaps using Python V2 instead of Python V3?  To force the version try:
python3 meraki-backup.py <api-key> "Ardent Network Inc"
I have also updated the script to include the SNMP fix, and an issue with SSIDs.  So you should download a fresh copy.  You may still get some errors, but you should get a reasonable restore script produced.
I am using python 3.6
The old script worked with me fine with Python 3.6, all I did was go into my network-wide settings and just enabled SNMP and set anonymous community strings which did the trick.
I will check that.
I just tried the script and seems to work fine, at least i can not see any errors but where the results are written ??  which folder ?
The results are written to the "current working directory" - so whatever directory you ran the command in, the restore script will be in.
oh ok , sorry Philip, i thougth that the results were written on a file other that the restore script. I see now that the "data" is inside the restore scripts itself. clear.
Thanks again.
Miguel Angel
Tried out the backup script. Had some problems getting it to run at first. Error was:
TypeError: __init__() got an unexpected keyword argument 'strict'
Reason was an out-of-date requests library. Fixed that by using:
pip install --upgrade requests
For testing I had created a dummy network that didn't have actual hardware in it but had some hardware independent settings changed. Had problems creating a backup with that somewhat empty network in my org:
  File "meraki-backup.py", line 187, in <module>
  File "meraki-backup.py", line 124, in write_ssid_settings
int)[0:-2]
TypeError: 'NoneType' object is not subscriptable
 Although the backup without that network was successful I'm not really willing to try out whether restore works on my real networks.
I think that Meraki should allow for some kind of backup natively.
Thanks for the feedback!  I don't think I have tested it out on a network with no devices in it.  I'll give that a try sometime.
@PhilipDAth
Have you considered putting this script under version control on GitHub? Would be a great way to for people to track changes/updates and contribute to the code base.
I hadn't considered it.  I'm not a proper developer ...
I too am receiving errors when running the script. Both on Organizations with and without devices on their network. See below.
Python 3.6.5
requests  2.18.4
meraki 0.33
  File "meraki-backup.py", line 159, in <module>
    write_admins(file,apikey, orgid, suppressprint);
  File "meraki-backup.py", line 53, in write_admins
    for row in myOrgAdmins:
TypeError: 'NoneType' object is not iterable
Just browsing
Hello Team,
I am facing below problem,
PS C:\Users\USER\Documents\Python> python3 meraki-backup.py xxxxxx "xxxxxx"
File "meraki-backup.py", line 142, in <module>
orgid=get_org_id(apikey,args.orgName,suppressprint)
File "meraki-backup.py", line 13, in get_org_id
result = meraki.myorgaccess(apikey, suppressprint)
AttributeError: module 'meraki' has no attribute 'myorgaccess'
Using python 3.7.5 on windows 10.
Sita
I just tried it and it worked for me.
If you are on Windows did you do the following from an Administrative prompt?
pip install requests
pip install meraki
Are you sure the API key you are using has full administrator access?  It sounds like it does not have rights to access the list of organisations.
Just browsing
Hello Philip,
Yes, I have already installed requests and meraki modules using pip.
API key that has been generated have full administrative access to only meraki organization we have.
LOL! You need a python script to half-ass backup the Meraki config?  Cisco you're the best!
The easiest way to back it up is to just copy it.  However this backup is kept in the cloud.  A small number of people prefer to have an offline backup.
The script made some problems for me, because i have switch or wifi networks without fw rules. So I simply insert a try except block in line 185. Now it works like a charm. Great work so far, hope we can add switch configs and device assignment into the code.
Thanks a lot!
Thanks for the feedback and the tip.  That should have worked fine with no firewall rules applied.
The whole system need a bits of a refresh.  Perhaps a holiday break project.
Hello Philip, thanks for the script. I tried to backup my conf and it worked well; now I'm trying to restore it and I'm getting this error:
but I'm not confident with python and I can't resolve it
I've released a completely refreshed version of the offline backup/restore system now.
https://www.ifm.net.nz/cookbooks/meraki-backup.html
@DiegoAMorelli this should resolve your issue as well.
