Is it OK to ignore IP conflict alerts with old clients?
from_afar
It seems that it's not possible to delete clients from the interface. As such, is it then OK to ignore IP conflict event logs for devices that have had their IP address changed and/or are no longer part of the network?
I have a NAS device that has 4 NICs. I had the device connected via a couple of the NICs as I was setting everything up and I eventually created a BOND on the NAS with several NICs combined. Since then, I have been seeing ip conflict entries in the event log because Meraki sees that the new bond IP address is the same as one of the previous individual NIC addresses.
Is it OK to ignore these events? Or is there a way to remote old clients from the system that I have missed?
Clients that haven’t been seen in the dashboard for 30 days will naturally transition out. So, if these old clients are no longer part of your network, they will eventually disappear from the system.
https://documentation.meraki.com/General_Administration/Privacy_and_Security/Cloud_Data_Retention_Po...
1 Reply 1
