We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
Dear, All
Now, I make design of NW using vMX100
Could you teach me how many site-to-site VPN sessions can vMX100 have?
# In datasheet, only 500Mbps throughput is written.
We’d like to make over 1000 VPNs, Can I?
Solved! Go to solution.
Hi
I believe the vMX100 have the similar capabilities as a physical MX appliance
The following url on the Page No. 3 suggests upto 250 Max concurrent VPN tunnels.
https://meraki.cisco.com/lib/pdf/meraki_whitepaper_mx_sizing_guide.pdf
As far as I know, vMX is sized equivalent to the regular MX100 as @AjitKumar suggests. Given then, 250 concurrent client VPN sessions is what you should shoot for as a max.
Hi, all
Thank you for replying!
Do you know how I can have over 250 VPNs using vMX?
And if you have design guide of VMX, please share me.
Unfortunately there are no deployment guides for the vMX yet other than the deployment instructions here: https://documentation.meraki.com/MX-Z/Installation_Guides/vMX100_Setup_Guide_for_Microsoft_Azure & https://documentation.meraki.com/MX-Z/Installation_Guides/vMX100_Setup_Guide_for_Amazon_AWS
As @kevinl mentioned, you can deploy multiple vMX appliances to scale the VPN connections.
