Clients Blocked from using LAN" from Yes to No
Ajesh
Hi Team,
Previously i have created one SSID for the guest users of the company to provide internet access to them and it was restricted to access the internal network so that i have selected 'Yes' option in "Clients Blocked from using LAN".
Now i have changed the SSID from guest user to internal user but i am unable to change the "Clients Blocked from using LAN" from Yes to No, kindly suggest how can i do the change so that the connected user of that SSID can access the internal network.
Have you tried creating a new SSID? When you say you changed it from yes to no, do you mean you changed it from Deny to allow?
2 Replies 2
Ajesh
Hi Alemabrahao,
Thanks for the update, i have made the changes and it's working now.
