I
@cmr wrote:
I was looking into using adaptive policy and it seems that objects can only be matched on CIDR. I was wanting to use it in lieu of Smartports not being supported on any of the Catalyst based switches. This would require matching on MAC or something else that does not seem to be supported.
Is there a way of putting IoT devices of a known type into a specific VLAN other than Smartports? Or is there a plan to roll Smartports out to the C9x00 switches?
Yes, using MAB with RADIUS or profiling with ISE on Catalyst C9k. On Meraki MS, also possible via MAB (but less granular, no native profiling).
