A new candidate appliance firmware version is available. Firmware MX 19.1.7.1 was just released on 2025-02-05 and has been in this firmware category since 2025-02-05.
As of MX 19.1, Cisco Meraki will no longer support USB-based Cellular Failover on the MX and Z platforms.
Legacy products notice
When configured for this version, Z1 devices will run MX 14.56.
When configured for this version, MX400 and MX600 devices will run MX 16.16.9.
When configured for this version, MX64(W), MX65(W), MX84, MX100, and vMX100 devices will run MX 18.107.12.
Bug fixes - limited platform fixes
Fixed an MX 19.1.7 regression that could result in MX75, MX85, MX95, MX105, MX250, and MX450 appliances servicing many clients to experience intermittent periods of heightened packet drops and latency. This resolves known issue MX-36338.
Known issues status
This list is being reviewed and updated.
Known issues
During the upgrade process, MX appliances upgrading from version prior to MX 19 may experience a failure to properly classify traffic. This issue will be resolved once the appliance has completed the upgrade to MX 19. (MX-36307)
Due to an issue under investigation, MX appliances may incorrectly route traffic destined to subnets learned through eBGP over a Non-Meraki VPN connection. (MX-34803)
Duplicate retrospective “malware download detected” emails may be erroneously sent. (MX-30111)
Due to an issue under investigation, making certain configuration changes to WAN interfaces (such as disabling or enabling an interface) can cause the IDPS process to fail. This issue may also cause high device utilization. The issue can be worked around by rebooting the MX appliance or disabling and then re-enabling IDPS. (MX-34504)
Due to an MX 19.1.5 regression, Z4(C) appliances may fail to provide PoE power to connected devices. (MX-34938)
Due to an MX 19.1 regression, traffic will fail to route over AutoVPN when the only active uplink is a cellular connection. (MX-35703)
Due to an issue under investigation, MX75, MX85, MX95, MX105, MX250, and MX450 appliances may experience an unexpected device reboot when VPN NAT is configured. (MX-36180)
When failover is configured between non-Meraki VPN tunnels, the Route Table page on Dashboard may incorrectly show the route for the primary VPN tunnel is inactive. (MX-36316)
During the upgrade process, MX appliances upgrading from versions prior to MX 19 will experience a failure to connect to non-Meraki VPN peers if any VPN peer names contain a space. This issue will be resolved once the appliance has completed the upgrade to MX 19. (MX-36312)
To start contributing, simply sign in with your Cisco ID. If you don't yet have a Cisco ID, you can sign up.
