A new beta sensor firmware version is available. Firmware MT 2.0 was just released on 2024-04-25 and has been in this firmware category since 2024-04-25.
Update MT20 and MT30 battery state of charge curves to be more accurate. Reported battery percentages will be lower than previously reported after this upgrade by up to 20%. Overall battery life remains unchanged as this changes the battery reporting and not the actual battery life.
Updated MT14 PM2.5 sensor fan cleaning behavior. No major behavior change expected, cleaning should still run every 3 days.
Internally overhauled alerting wake-up logic. No behavior change expected.
Internal bug fixes and performance improvements
To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
