Search instead for
Turn off Auto Tag IOS
I am probably missing the setting, but is there a way to turn off Auto Tags , i have 2 profiles installed on 1 Ipad which is messing with Imessage settings  , i can't change the settings for the tag  "IOS Devices"  profile because it will mess up other ipads , but when i goto this particular Ipad i see my manual tag but i can't see how to remove the Auto tag " IOS Devices on this IPAD
Accepted Solutions
Re: Turn off Auto Tag IOS
@Mike_YMCAMIDTN Add an exclusion tag to the restriction profile causing problems and then add that exclusion tag to the device you want to exclude. Follow the example below.
Use WITHOUT ANY of the following tags
Add iOS Devices & Exclusions
Make sure installation target states: iOS Devices without any of the followings tags Exclusions
3 REPLIES 3
You can't remove an auto tag.
It is probably easiest to create a new tag, say "ProfileA". Assign it to all the current devices, and ten change your profile to apply to this rather than the AutoTag.
Another option is to create another Systems Manager network, and move the one device into it.
Thanks @jared_f I will give that a try
Points Contest
Join us for a month-long contest with heaps of swag to win!
Learn More ›
