Search instead for
Feature Request: Ability to Create the Same Profiles from Server in Meraki
I am aware that you can download profiles you create in OSX Server and upload them to Meraki, but this is extremely difficult to track versions. I invite others to wish that the full suite of profiles was available to admins. If this is already in the works, I can't wait lol!
Thanks!
1 REPLY
Re: Feature Request: Ability to Create the Same Profiles from Server in Meraki
Yep. Apple will add even more MDM configurable options in High Sierra 10.13.4, including the ability to defer software updates by X days.
The feature I would really love to have is the FileVault personal recovery key escrow. You can create that right now in Profile Manager, but it won't work because that's assuming you have a on-prem solution using macOS Server for MDM vs Meraki.
