Streamlining Meraki EOL page
rhbirkelund
I'm working on something with the Meraki EOL page, but I'm having difficulty in getting a clean and consistent result with my script, due to the fact that some of the entries in the EoL page do not follow the same "formatting" as other entries.
E.g. the MX64 and MX64W are in the same row.Or the MV21 and MV71 cameras being different models with same EoL date, and being on the same row, in contrast to some other devices.
It would also be nice, if the entries would be specifc models, rather than just "MS220 series".
Also, perhaps move the country specific codes to a column itself?
It would also be nice, if the dates would be consistent aswell, instead of switching back and forth between e.g. "Jul" and "July".
9 Replies 9
KarstenI
After thinking about it, all the EOL information should be available via the API, with the results being clean JSON objects.
rhbirkelund
Are they, or is it just a suggestion? Because I'd love if it was already an endpoint. 🙂
KarstenI
Nothing more than a little daydream. At least I am not aware of something like this.
rhbirkelund
Fair enough. Must have been more of a fever dream then. 😂
JamesT91
This may do something similar (haven't tried it, so can't verify): Francisco-1088/merakiLifecycleReport - Cisco Code Exchange
rhbirkelund
Thanks for the reference. It doesn't really seem to be maintained, since it's using old modules. I'll look into it though. 🙂
I just had an idea.  Cisco has an "EoX" API.  I wonder if you can look up Meraki part codes with that.
https://developer.cisco.com/docs/support-apis/#!eox/get-eox-by-dates
rhbirkelund
Uuh.. I did just finish my modified version of the one that @JamesT91 referenced, but I’ll take a look at the EoX api. 😄
rhbirkelund
Meh.
I got so far as to generating an access token, after registering my app.
But the EoX endpoint fails with "Developer Inactive", and this seems to be a known "issue", where one has to go through TAC to get that fixed according to Cisco Community.
The apix.cisco.com/hello, seems to work, so something must be okay, though.
But this should be the way to do it. I just can't check it. Assuming the "app" is registered in Cisco API Console
curl -L --request POST \
--url "https://id.cisco.com/oauth2/default/v1/token" \
--header 'Content-Type: application/x-www-form-urlencoded' \
--data 'grant_type=client_credentials&client_id=[AwesomeClientId]&client_secret=[AwesomeClientSecret]'
which returns the access token to be used in;
curl --location 'https://apix.cisco.com/supporttools/eox/rest/5/EOXBySerialNumber/1/[serial]?responseencoding=json' --header 'Authorization: Bearer MyAwesomeAccessToken'
