SecurePort (formerly known as SecureConnect)
Does SecurePort not work with the MS130, any of the C9x00 switches, the CW9163E or the CW9166D1?  If it does then please update here:
On a non-documentation note, if you try to enable it in a network that only has unsupported switches the error message still references SecureConnect:
RaphaelL
Bookworm is proud of you cmr.
Also I found this in the Alert Hub of my org :
I opened a case about it.
It was only renamed about 2 years ago, the cloud needs time to absorb the change... 😉
I would like to use this feature, but I never had a combination of hardware together that it works with.
rhbirkelund
They might also want to mention that SecurePort is not supported in combination with SmartPort Automations.
