Missing diagram or extraneous heading
On this page: Using the Cable Test Live tool - Cisco Meraki Documentation
At the bottom there is a heading for a straight through cable and good diagram below.  There is then a heading for a cross over cable, but no diagram.
There should either be no cross over heading or a diagram for a cross over cable.  I'd suggest simply removing the heading as I can't remember the last time I needed a cross over cable, it must have been in the 2000s or possibly the 2010s...
JonoM
Meraki Employee All-Star
This has now been updated!
5 Replies 5
DarrenOC
Crikey, can’t remember the last time I needed a cross over cable!
pdeleuw
Remember: If you configure speed and duplex statically, auto sensing will be deactivated. This is the moment, you will need crossover cable.
JonoM
Hi @cmr , thanks for bringing this to our attention! I am raising this internally to see if we can get this updated. Will drop a message here once I get confirmation on an update 😄
JonoM
Thanks @JonoM 🎉
