Documentation addition - TCN Switch_Port_View
RaphaelL
Hi ,
The section "Packets" from : https://documentation.meraki.com/MS/Monitoring_and_Reporting/Switch_Port_View
should now include 'Topology changes'
This section displays detailed packet information in relation to the selected switch port, including the total, sent, received and rate values for Total, Broadcast, and Multicast traffic. This table will also display counters for CRC align errors, Fragments, and Collisions. An example is provided in figure 3 below.
Suggestion :
This section displays detailed packet information in relation to the selected switch port, including the total, sent, received and rate values for Total, Broadcast, and Multicast traffic. This table will also display counters for CRC align errors, Fragments, Collisions and Topology Changes. An example is provided in figure 3 below.
And update the corresponding screenshot 🙂
Thanks !
FeliA
Hi @RaphaelL,
The edits to the documentation are now complete. Much appreciated.
Best,
Feli
If you found this post helpful, please give it kudos. If this answer helped solve the issue, click "accept as solution" so that others can benefit from it.
2 Replies 2
FeliA
Hello @RaphaelL,
Great catch! Thank you 🙂
Your suggestions have been forwarded, and I'll provide an update once these adjustments are complete.
FeliA
Hi @RaphaelL,
Best,
Feli
