- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
updateOrganizationLoginSecurity
Hi All,
Hopefully a simple question, i've only used the api to get data previously but have come up with a use case where we would like to update the loginIpRanges within the updateOrganizationLoginSecurity.
What i'm not sure about, and have failed to find out via searching the net.
With the " /organizations/{organizationId}/loginSecurity" end point do we need to include all the object values or can we just pass the loginIpRanges
so can we just do (data is from
"loginIpRanges": [
"192.195.83.1",
"192.195.83.255"
or do we need to include all of it...
"enforcePasswordExpiration": true,
"passwordExpirationDays": 90,
"enforceDifferentPasswords": true,
"numDifferentPasswords": 3,
"enforceStrongPasswords": true,
"enforceAccountLockout": true,
"accountLockoutAttempts": 3,
"enforceIdleTimeout": true,
"idleTimeoutMinutes": 30,
"enforceTwoFactorAuth": true,
"enforceLoginIpRanges": true,
"loginIpRanges": [
"192.195.83.1",
"192.195.83.255"
"apiAuthentication": {
"ipRestrictionsForKeys": {
"enabled": true,
"ranges": [
"192.195.83.1",
"192.168.33.33"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
the answer was through self testing, you can just upload the one bit of information, and leave the rest untouched.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @tcanty glad you got the answer, but in the future, you can see in the docs that there are no required parameters.
Hope this helps!
https://developer.cisco.com/meraki/api-v1/#!update-organization-login-security
