stickyMacAllowList error must be an array
eroche
Having an issue with trying to update the stickyMacAllowList value. Doesn't matter if I leave it blank to try and remove the current mac address or if I add a valid mac (xx:xx:xx:xx:xx:xx) I keep getting the following error:
400 Bad Request, {'errors': ["'stickyMacAllowList' must be an array"]}
Below is my full code. Thanks in advance.
import meraki
import os
import time
import pprint
from colorama import init as colorama_init
from colorama import Fore, Back
from colorama import Style
import inquirer
from inquirer.themes import GreenPassion
import progressbar
def get_meraki_api_key():
    api_key = os.getenv('MERAKI_API_KEY')
    if not api_key:
        raise ValueError("No API key found. Please set the MERAKI_API_KEY enviroment variable.")
    return api_key
# Select Device
sw_sn = 'my sn'
port = input ('\n' + 'What port would you like to update? (1,2...48): ')
print (Fore.BLUE,Style.BRIGHT +'\n' + 'Below is the current information for that port:  ' + '\n')
API_KEY = get_meraki_api_key()
dashboard = meraki.DashboardAPI(API_KEY, suppress_logging=True)
serial = (sw_sn)
port_id = (port)
response = dashboard.switch.getDeviceSwitchPort(serial, port_id)
fields = ['portId', 'name', 'enabled', 'poeEnabled', 'type', 'vlan', 'voiceVlan', 'allowedVlans', 'accessPolicyType','isolationEnabled', 'rstpEnabled', 'stpGuard', 'linkNegotiation']
for field in fields:
    print (f"{field}: {response[field]}")
# Update settings
def update_values():
    print (Fore.YELLOW,Style.BRIGHT +'\n' + 'Please enter the updated values, which are Case-Sensitive:  ' + '\n')
    v_allowed = ""
    mac_allowed = ""
    sticky_mac_allowed = ""
    mac_allowed_limit = ""
    v_vlan = ""
    port_name = input ('\n' + 'Port Name:  ')
    enable = input ('Enable Port [True or False]:  ')
    port_type = input ('Port Type [trunk or access]:  ')
    d_vlan = input ('Data VLAN:  ')
    if port_type == ('access'):
        v_vlan = input ('Voice VLAN:  ')
    if port_type == ('trunk'):
        v_allowed = input ('Allowed VLANs [1,3 or 1-3 or All]: ')
    rstp_enabled = input ('RSTP Enable [True or False]:  ')
    stp_guard = input ('STP Guard [disabled, root guard, bpdu guard, loop guard]:  ')
        access_policy = input ('Access Policy [MAC allow list, Open, Sticky MAC allow list]:  ')
    if access_policy == ('MAC allow list'):
       mac_allowed = input ('MAC Address [xx:xx:xx:xx:xx:xx, xx:xx:xx:xx:xx:xx): ')
    if access_policy == ('Sticky MAC allow list'):
        sticky_mac_allowed = input ('MAC Address [xx:xx:xx:xx:xx:xx, xx:xx:xx:xx:xx:xx]: ')
        #mac_allowed_limit = input ('How many MAC Address Allowed: ') Commented until above fixed
    poe_enabled = input ('PoE Enabled [True or False]:  ')
    response_update = {}
    if port_name:
        response_update["name"] = port_name
    if enable:
        response_update["enabled"] = enable
    if port_type:
        response_update["type"] = port_type
    if d_vlan != '':
        response_update["vlan"] = d_vlan
    if v_vlan != '':
        response_update["voiceVlan"] = v_vlan
    if v_allowed == '0':
        response_update["allowedVlans"] = v_allowed
    if rstp_enabled:
        response_update["rstpEnabled"] = rstp_enabled
    if stp_guard:
        response_update["stpGuard"] = stp_guard
    if access_policy:
        response_update["accessPolicyType"] = access_policy
    if mac_allowed:
        response_update["macAllowList"] = mac_allowed
    if sticky_mac_allowed:
        response_update["stickyMacAllowList"] = sticky_mac_allowed
    if mac_allowed_limit != '':
        response_update["stickyMacAllowListLimit"]
    if poe_enabled:
        response_update["poeEnabled"] = poe_enabled
    fields = response_update
    print (Fore.WHITE,Style.BRIGHT + '\n' + 'Here are the values you entered')
        print (f"{field}: {response_update[field]}")
    validate = input ('\n' + 'Are all values correct [Y or N]:  ')
    if validate in {'Y', 'y'}:
        response = dashboard.switch.updateDeviceSwitchPort(serial, port_id,**response_update,)
        print (Fore.GREEN,Style.BRIGHT + '\n' + 'Here are the New Settings: ' + '\n')
        input  ('\n' + 'Press Enter to return to Main Menu: ')
        main_menu()
    elif validate in {'N', 'n'}:
        input (Fore.MAGENTA + Style.BRIGHT + '\n' + 'Darn, Ok lets try this again, press Enter: ')
        #clearconsole()
        print (Fore.BLUE,Style.BRIGHT +'\n' + 'Current Values:' + '\n')
        fields = ['portId', 'name', 'enabled', 'poeEnabled', 'type', 'vlan', 'voiceVlan', 'allowedVlans', 'isolationEnabled', 'rstpEnabled', 'stpGuard', 'linkNegotiation']
        update_values()
    else:
        print ('you need to select Y,y,N or n')
update_values()
sungod
The error is because that variable needs to be a list, but you are using a simple variable.
As @PhilipDAth says, look at an example return data to see which are lists, or look at the API documentation, there is an example response.
I don't see any way for the inquirer library to return a list, you'll just get a string. So you'll need to parse the string into a list.
This might work...
m = input ('MAC Address, enter one or more separated by space xx:xx:xx:xx:xx:xx : ')
mac_allowed = list(m.split(" "))
6 Replies 6
What I often do for these kinds of problems is create the configuration in the Dashboard, then "Get" the config - and see how the data is formatted.
Should this line:
be?
sungod
This might work...
eroche
this worked thanks......one last question kind of with this topic.....can we clear the Sticky MAC Address through API, same task as clearing port security on a Cisco switch.
Not tested.  Try specifying an empty array.
eroche
Yeah I thought I did that in the very very beginning but now trying that where I am at now it keeps failing with a error for the value not being a mac address.
I will just try it again from the basic script for that one thing and see what happens. Worse case I will just open another topic😉
