"send test webhook" failing to Slack
CrazyIvan
Howdy, I am testing integration of webhooks with Slack (just signed for the payload templates beta) and for some reason, I can't pass the "send test webhook" test on the configuration page. I am sure the Slack URL and shared secret are correct. Should this work as is or is there something needed on the Slack side to make it work? At this point, I just want to see that Slack is getting the test from the Meraki dashboard. I also can't see where I could get some logs on why this is failing. Any ideas?
Inderdeep
Check the link below, it may help you
https://community.meraki.com/t5/Developers-APIs/Webhooks-in-Slack-or-Teams/m-p/31791#M759
Regards/Inder
www.thenetworkdna.com
2 Replies 2
Inderdeep
Regards/Inder
CrazyIvan
Thank you, that makes perfect sense. I suppose the payload templates dashboard function (beta) will eliminate the need of the middle ware to convert this... did I get that right?
