organizationId/devices/availabilities API doesn't return C9300-M.
jtlonginAuburn
When running the {{baseUrl}}/organizations/:organizationId/devices/availabilities to get status for current devices none of my C9300-M switches are returned. I see all of my wireless devices and native Meraki MS switches but my 9300's running Meraki code are not showing up. To be clear, these are not catalyst monitored cisco ios devices but native 9300's.
Is there another way to get the current online status of devices? I'm using  /organizations/:organizationId/devices/availabilities/changeHistory for now but with my script that is proving difficult to get current status.
5 Replies 5
Mloraditch
I just ran the same call and my 9300s show up. Are you using any filters? Mine are 9300Ls so perhaps slightly different than your org, but that shouldn't matter.
jtlonginAuburn
No filters, what I put in the original post is the exact postman call.
Mloraditch
Seems most likely a bug you'd need to open a support case on then. I used postman as well for mine.
Perhaps this is firmware related.  What version are you using @jtlonginAuburn and @Mloraditch ?
Mloraditch
17.1.4 for me.
