get_network_devices(network_id) JSON transformation
Farrukh
Output generated from  get_network_devices(network_id) API is below need to transform it to other format
"address": "",
"firmware": "switch-11-22",
"floorPlanId": null,
"lanIp": "192.168.128.42",
"lat": 37.4180951010362,
"lng": -122.098531723022,
"model": "MS220-8P",
"name": "Office Switch",
"switchProfileId": null
need to transform it into mapping for geo plotting in kibana
   "mappings": {
      "_doc": {
         "properties": {
            "location": {
               "type": "geo_point"
for kibana the mapping information have to be in the formate below
   "mappings": {
      "_doc": {
         "properties": {
            "location": {
               "type": "geo_point"
and sample data look like this
{"index":{"_id":1}}
{"location": "2.089330000000046,41.47367000000008", "city": "SantCugat"}
{"index":{"_id":2}}
{"location": "2.2947825000000677,41.601800991000076", "city": "Granollers"}
{"index":{"_id":3}}
{"location": "2.1105957495300474,41.5496295760424", "city": "Sabadell"}
{"index":{"_id":4}}
{"location": "2.132605678083895,41.5370461908878", "city": "Barbera"}
{"index":{"_id":5}}
{"location": "2.151270020052683,41.497779918345415", "city": "Cerdanyola"}
4 REPLIES 4
RaphaelL
Could you be more precise on your question ?
1-What element from the output of the API do you need ?
2- Could you sample a complete ''geo plotting in kibana ''
   "mappings": {
      "_doc": {
         "properties": {
            "location": {
               "type": "geo_point"
{"index":{"_id":1}}
{"index":{"_id":2}}
{"index":{"_id":3}}
{"index":{"_id":4}}
{"index":{"_id":5}}
Raj66
Hi @Farrukh
Some of the information in the JSON output you have provided is very sensitive, it is not a good idea to post it publicly as it could be used for malicious activity. Can you please mask out the serial number, network id, lat/lng of the device, please? This information is sensitive and it is always a good idea to protect them.
Cheers!
Raj
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
Farrukh
actual it is Cisco test lab no need to worry
