beginer for API
Scott_CC
beginer for API
Hello
I have enough network knowledge and Meraki dashboard experience for dashboard UI process.
Because of SDWAN enroll, I have large setup task. So I need the skill for automation.
But I found below course don't help me. It more like a quick guide use for developer but I am not developer.
Meraki APIs Using Node-RED
It don't have sample for one of below topic.
  1. create network like build-in tools Bulk network creation.
  2. update device IP and relate information.
  3. change MX subnet
  4. update device address.
  5. move device
  6. delete device or network
  7. claim device or unclaim device.
May you please guide me how to learn relate knowledge? Any document, guide and sample are welcome.
Python open to learn. I have a Python book, but it also don't have sample for my request.
Thanks for your help.
Best Regards
Scott
6 Replies 6
rhbirkelund
Before jumping out into the Meraki API, you might want to consider getting the python basics first.
My employer ran an internal python course where part of it, was going through this Coursera course on Python.
I found it okay, although I already had been doing some stuff in Python.
Scott_CC
Hello
when I follow https://developer.cisco.com/meraki/ to get Org, I get below error.
ERROR > organizations, getOrganizations - 401 Unauthorized, {'errors': ['Invalid API key']}
I think I should set URL to properly region. May you please advise how to define URL?
Thank you.
Best Regards.
Scott Gao
You could also look at third-party commercial tools like Boundless Digital.
https://www.boundlessdigital.com/network-management/meraki-automation/
Scott_CC
Hello Philip
Thank you.
Best Regards.
Scott Gao
Have you already enabled API usage and generated the API key?
https://documentation.meraki.com/General_Administration/Other_Topics/Cisco_Meraki_Dashboard_API
Scott_CC
Hello
I success by below code for my first query.
Thank you.
base_url = 'https://api.meraki.cn/api/v1'
API_KEY = "****************"
import meraki
dashboard = meraki.DashboardAPI(API_KEY,base_url)
response = dashboard.organizations.getOrganizations()
print(response)
