I wrote a small script which will generate QRCodes for configured SSIDs. The script is using asyncio and api version 1.
usage: generate_qrcodes.py [-h] [-o ORGANIZATION] [-n NETWORKS [NETWORKS ...]]
[-s SSIDS [SSIDS ...]]
Generates QRCodes from Meraki wireless networks
optional arguments:
-h, --help show this help message and exit
-o ORGANIZATION, --organization ORGANIZATION
the name/id of the organization
-n NETWORKS [NETWORKS ...], --network NETWORKS [NETWORKS ...]
the name/id of the networks to generate the qr codes
from. If you are providing this parameter, then you must
provide the organization.
-s SSIDS [SSIDS ...], --ssid SSIDS [SSIDS ...]
the name of the ssids to generate the qr codes
You have to provide at least the organization or network parameter.
the QRCodes will be places in a subdirectory "img". The Filename is {NetworkName}_{SSID}.png.
Example:
Very cool!
I am interested in trying this out. Do you know if this script is still valid. ....
yes it is still working fine. There is a deprecation warning, which can be ignored at the moment.
Just to confirm, this will let me create a QR Code for a guest wifi access with a splash page? Also, I am getting a SSL: CERTIFICATE_VERIFY_FAILED on trying, and I guess I have to setup a certificate in addition to the API KEY. Do you know where I can find info on setting up a certificate for Meraki?
Thanks in advance for your help.
I was able to get this working, but I have a question on the user experience, as the QR codes are asking me to joint the guest wifi network, but it is not causing the splash page to come up. I can share a video if you want to see.
hello @Fantasticmrfox can you please share the video of how you were able to get the QR codes working?
Thanks!
