Weebhook for non primary links
beltranesteva
I was wondering if anyone knows how to configure a weebhook to send an alert when a non primary link goes down or has poor performance. I am trying to avoid having to, every X amount of time, make an API call and check how things are doing.
Thanks!
Beltrán
You could „Make a wish“ on the alerts page and hope it‘ll be implemented sometime
jdsilva
Hi @beltranesteva, unfortunately what you're asking is not currently possible. Webhooks are limited to what is available on the Network-wide > Alerts page and that's it.
Hi @jdsilva, thanks for your answer. Any suggestions in an alternative way to achieve it? Or i should continuosly chek through the API and see its status?
Thanks!
