- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Webhook statistics
We have recently discovered that a number of Webhooks were not delievered due to an authentication issue.
Is there an API endpoint for retrieving Webhook delivery logs / stats?
If not, please could one be added?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Get Organization Webhooks Logs
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks @michalc! Not sure why I couldn't find that!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@michalcI see that there are responseCodes of -1. What does that indicate? It would be useful to also have information relating to DNS, TCP and SSL, as follows:
"dnsSuccess": true,
"tcpSuccess": true,
"sslSuccess": false,
"httpSuccess": null
From this, we would be able to determine that the HTTP negotiation failed at the SSL stage.
Can I ask for that to be fed back to the product team?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It gets worse. There are no unique ids on the records and there are multiple indentical records (all fields are the same), down to the microsecond. Are the repetitions down to retry attempts? If so, the "sentAt" fields should be updated and ideally there would be an "attemptIndex" property. Please could we (at least) have a unique id added to each so that we can tell them apart?
Example (details changed to protect the innocent):
"alertType": "APs went down",
"loggedAt": "2025-03-12T15:24:37.973999Z",
"networkId": "N_123123123123123123",
"organizationId": "123123",
"responseCode": -1,
"responseDuration": 6007,
"sentAt": "2025-03-12T15:24:31.964999Z",
"url": "https://webhooks.example.com/api/Endpoint?xxx=yyy"
"responseCode": -1,
