Update Port tags based on vlan
Capt_Caaaveman
I am trying to create an API to update a switch port tags based on the assigned vlan.
This runs without error but doesn't update the ports, or it updates one port that isnt in the vlans listed.
import meraki
API_KEY = 'xxxxx'
ORG_ID = 'xxxx'
NET_ID = 'xxx'
Serial = 'xxx'
# Create Meraki API Dashboard interface
dashboard = meraki.DashboardAPI(API_KEY, suppress_logging=True)
# Define VLANs and their corresponding tags
vlan_tag_mapping = {
2: ["device_1"],
5: ["device_2"],
10: ["device_3"],
# Get switch ports
switch_ports = dashboard.switch.getDeviceSwitchPorts(Serial)
# Iterate through each switch port
for port in switch_ports:
vlan_id = port.get("vlan")
port_id = port.get("portId")
# Check if the port's VLAN is in the mapping
if vlan_id in vlan_tag_mapping:
new_tags = vlan_tag_mapping[vlan_id]
# Update the port with new tags
dashboard.switch.updateDeviceSwitchPort(
Serial, portId=port_id,
tags=new_tags,
The updateDeviceSwitchPort call should be inside the if block to ensure it only updates ports with VLANs in the mapping. If a port's VLAN is not in the mapping, it might be helpful to handle that case explicitly.
Try this code:
NOTE: (I forgot to mention that it is your code and I just added a print at the end).
import meraki
API_KEY = 'xxxxx'
ORG_ID = 'xxxx'
NET_ID = 'xxx'
Serial = 'xxx'
2: ["device_1"],
5: ["device_2"],
10: ["device_3"],
# Get switch ports
tags=new_tags,
else:
print(f"Port {port_id} with VLAN {vlan_id} not in mapping.")
Capt_Caaaveman
Thank you.
I get
tags=new_tags,
NameError: name 'new_tags' is not defined
I got it, It looks like the new_tags variable isn't being defined properly before the updateDeviceSwitchPort call. To fix this, ensure that new_tags is defined within the scope of the if block.
e.g.
