Webhook for listening to client connectivity changed?
Hello Team,
I've been working on a solution to monitor when clients connect to a Wifi Network. I found the following Webhook sample alert on the Cisco documentation (https://developer.cisco.com/meraki/webhooks/#!webhook-sample-alerts/client-connectivity-changed), however I'm not sure how I would configure a webhook to listen for this type of event. Does anyone have any knowledge on if this is possible, or potentially an alternative solution for listening to Client connectivity changed events? Thank you.
Hi, I would be writing my own code to do this, I wanted to know if it would be possible to leverage the existing Meraki webhooks in order to listen for this type of event. Thanks for your response.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_67cafe28696b94","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_67cafe28696b94_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_67cafe28696b94_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_67cafe28696b94_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_67cafe20d42aaa","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
