Using the API to get and update the DHCP Settings for networks without a VLAN setup
NJNetworkGuy100
Does the 1.x API allow for getting and updating the DHCP settings for networks without a VLAN setup on it?  We have a bunch of job sites (using a MX/MG setup) that use the standard subnet settings with no VLAN's setup.  They don't use a S2S VPN, and keeping things generic makes it easy to move the MX/MG kits around to new sites.
Looking to make sure they are all setup properly with the right DNS servers in DHCP.
Accepted Solutions
Re: Using the API to get and update the DHCP Settings for networks without a VLAN setup
I don't know the answer for sure - but I'm about 75% confident you can't do anything with DHCP on an MX unless VLANs are enabled.
You'd have to try it for sure.  I would start by trying to retrieve the config.  If you can't do that - you won't be able to update it.
2 REPLIES 2
NJNetworkGuy100
That's what I'm thinking too.  I can't see any other way to find or change that info with the 1.x version of the API.  I was just hoping it was something staring me in the face that I was missing!  Thanks!
