Use of applications by network or access point
Carlos_Manuel
Hello, I would like to know if there is any service that returns the use of applications by network or access point, thanks
1 Reply 1
sungod
There's application usage by client (over a defined period), you'd need to get a list of clients, for instance...
https://developer.cisco.com/meraki/api-v1/#!get-device-clients
...and/or...
https://developer.cisco.com/meraki/api-v1/#!get-network-clients
...then call for each client...
https://developer.cisco.com/meraki/api-v1/#!get-network-clients-application-usage
I guess in some contexts a switch/AP might count as a client (try it and see), but typically it'll be a connected end-user device that's the 'user' of the application and it could be connecting to multiple APs and/or passing through multiple switches.
