Traffic Analysis - Filter or Custom Pie Chart
LucasMendes
Hello Guys!
I’m looking for a way to extract traffic statistics between clients and a set of apps.  I know that It is possible to get all users or network-wide traffic using the API calls below:
  • "/networks/{networkId}/clients/{clientMac}/trafficHistory "
  • "/networks/{networkId}/traffic";
But it’s a lot of traffic to deal with.
Using the custom pie chart you can view a summary of statistics about some application. Is there an API to query Custom Pie Chart data? Or is there a way to filter traffic before starting?
6 Replies 6
Inderdeep
LucasMendes
Thanks for your @Inderdeep, but I'm looking for an API to extract informations from Custom Pie Chart.
Inderdeep
LucasMendes
@Inderdeep
This API you've sent you get the configuration of Custom Pie Chart, but I would like the data of graph like in the image.
Inderdeep
@LucasMendes : I dont think so there is any API call for that !
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
LucasMendes
@InderdeepI think in same way. Thank you for answer.
